replaced engine no wont rev over 3 grand
ok guys i swapped my D16Z6 and when i started it,the rpms were rough and i tried to give it gas it wont go over 3 grand and bogs down any suggestions
Re: replaced engine no wont rev over 3 grand (1SOL2NV)
Are you throwing any codes? 'Cause when I did my swap, I had Map/TPS sensors switched for the longest time.
Re: replaced engine no wont rev over 3 grand (BADEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADEG6 »</TD></TR><TR><TD CLASS="quote">if you put a voltmeter on the tps it should be at like .42volts at closed position im not sure of the firng order but i will look it up for you</TD></TR></TABLE>
do i put it on the wire?
ok guys i replaced the tb gasket and its running good.I have another ? its smoking more than it should be what can i check for that?
Unceasing Measure
How bout your blood alcohol level? Jesus Christ, it's a D-series swap in a D-series chassis with all necessary D-series wiring. It's probably blowing moisture from sitting or oil from broken parts - of course we can't tell you which because you didn't detail the smoke.
[Jerry Meguiar]help me help you...HELP ME HELP YOU[/Jerry Meguiar]
Re: replaced engine no wont rev over 3 grand (Archidictus)
sorry its my first time and i can't afford to mess something up.....the smoke is white or light gray
radicaled434
04-28-2012 11:34 AM
