MAP sensor code problem.
Old Oct 23, 2004 | 08:08 PM
Intercooled JRSC's Avatar
Default MAP sensor code problem.
my 94 civic coupe is throwing a code 5, which should be MAP problem.
i also have a 94 integra gsr, so i swapped out the MAPS with each other, but still throw a code 5.
what else could i do to fix the code ? are the gsr and the civic MAP sensors the same ?
also, what else could i check to rectify the problem.
thanks to anyone who can help out a brotha'.
hatchi's Avatar
Default Re: MAP sensor code problem. (Intercooled JRSC)
you swapped them out but did you reset ecu??
Powered By Garrett
Dec 13, 2005 09:16 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
909rex
Jul 28, 2004 05:50 PM
