D16Y7 Auto - B16A2 Manual
I have been doing a lot of research, and finally these are the numbers i came up with. do they sound about right?
BTW, they are in canadian funds.
B16A2 Manual in a 2000 Civic D16Y7 automatic
Engine Swap
Motor
Transmission 5SPD Manual
Engine Wiring Harness
All required Cables
ECU
Distributor
Throttle Body
Clutch
Fly Wheel
Injectors
Intake Manifold
Exhaust Manifold
Starter
Alternator
A/C
Power Steering Pump
All Brackets and Sensors
$3000
Tranny Swap
Shiflinkage $40
Intermediate shaft $30
Clutch/brake/gas pedal assembly $60
Clutch master cylinder $50
Clutch reservoir& slave cylinder $30
Hydro clutch lines $40
Shift **** $15
Shift boot $15
$280
Misc
99-00 civic si rear tranny bracket 50827-s04-n10 $50
99-00 civic si drivers side bracket Honda P/N 11910-P30-000 $70
Axles $400
$520
Swap Total $3800 Canadian
the car is a 2000 Civic hatchback, and it is a daily driver so I think i will be happy with the b16a2.
also is it better to stay OBD2 or get an OBD1 motor?
peace
Engine Swap
Motor
All required Cables
ECU
Distributor
Throttle Body
Clutch
Fly Wheel
Injectors
Intake Manifold
Exhaust Manifold
Starter
Alternator
A/C
Power Steering Pump
$3000
Tranny Swap
Shiflinkage $40
Shift **** $15
Shift boot $15
$280
Misc
Axles $400
$520
peace
Re: D16Y7 Auto - B16A2 Manual (CivicHatchEK9)
If you DIY then it might come out that cheap, but the tranny is more expensive than that, at least here in the states.
GL anyhow
GL anyhow
Re: D16Y7 Auto - B16A2 Manual (Hazem)
but the engine is already going to come with the tranny, but I wanted to be sure that those are all the parts I will be needing, because once the car goes on jacks there is no other car for me to drive around and try to find extra parts.
if anyone has attempted this swap or knows of any obsticals I might face please let me know.
Naser
Naser
sorry hatchi, I don't have premission to use Private Messaging yet, just signed up today, but 3800 CDN = 3,081.16 USD
Midori Green
13
12-06-2006 04:56 PM
