starting project.
starting project.
i am starting my 92 civic hb swap soon. and i am making sure that the axles that i got from oreilys are going to fit into my hub. i got 94 integra axles, are they going to fit into where my d15b7 axles were? also what intermediate axle do i need, oreilys didnt carry it?
Re: starting project. (zdowell17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 »</TD></TR><TR><TD CLASS="quote">i am starting my 92 civic hb swap soon. and i am making sure that the axles that i got from oreilys are going to fit into my hub. i got 94 integra axles, are they going to fit into where my d15b7 axles were</TD></TR></TABLE>
Should fit. I had a d16z6 but the hubs had originally been the same as d16b7 (9.5" brakes). Splines all fit perfectly.
Re: starting project. (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 »</TD></TR><TR><TD CLASS="quote">yes, any 94+ 5spd integra cv axles and use same intermediate shaft</TD></TR></TABLE>
Correct.
If you have a 92 you have all the pre-wires for vtec so its much easier to hook up. Make sure to buy a gsr 02 sensor and it might be a good idea to buy a header for a Civic Si, or Integra LS, it will fit correctly (GSR manifold is the only of its size and is shorter).
My current set up in a 1992 cx hatch is b18c1, jdm DC 4-1 header, 15" Carsound cat with flanges on both sides, and greddy catback exhaust... fits perfect.
Correct.
Re: starting project. (jlsmi2)
i am going to only run the car for under a month maybe even less. I think i am going to just use my old one. then over the winter get a wide band, i am planning on also turbo. so i will be setting it up for that also over the winter. in the mean time i will be driving some kind of beater!
