possible clutch or tranny problems
ok so i was driving around tonight for all most an hour and i noticed when i was stopped at a red light i went to put it in first and it was hard and when it went in kinda clanked i guess you could call it. and every now and then when i would release the clutch it would stick for a second or two. and going into reverse i had to try probably almost 7 times. and everytime i would try i was at a complete stop and i would put it in another gear then try reverse. would this be a problem with the clutch not engaging woth a **** or is my tranny getting shitty? i havent ever changed tranny fluid would that help? and plus i have a dc sports short throw shifter which i hate. i havent saved enough money up for a skunk2 yet. the dc sports rattles like a bitch and it will barely fit in the shift linkage at the bottom. i put poly urethane bushings one night when i was drunk and did manage to forget the lube would that cause problems?
Re: possible clutch or tranny problems (forced00si)
the clutch i have in there is a re-manufactured one. are they pretty shitty? i could afford wut i wanted at the time so i had to go with wut i could afford. and with a spring being out i will have to basically replace the clutch or is it fixable?
master/slave cylinder? i have the same prob(not clutch sticking, but the 1st gear and reverse issues) and was told to put a new master/slave cylinder. ill let you know how it goes on monday/tuesday.
Re: possible clutch or tranny problems (eclypzex)
i put in a new clutch and its makeing an kinda grinding noise as i let out the clutch. i bought a new master/slave cylinder i dunno if it is the problem.
J-Brooks
12-17-2002 10:23 AM
