weird looking gsr head? HELP...
Okay heres the situation..
I inspected my gsr head and what do I find.. the valves are super close to the bottom surface of the head.. I am thinking that the owner before milled the head to extremes.. the valves are almost touching the bottom suface of the head.. Is this a milled head?
Is this safe to run on a gsr block with itr pistons and itr cams? If not, is there any way I could go around it without buying another head.. Could a thicker metal head gasket help.... Help me out guys..
Re: (b00sted93Hatch)
Yes, my head almost looks just almost like the pic ^ there..
Is that normal stock or a super milled head? mines look similar to it.. Is that bad or what?
I know a little mill is good like .030mm but I dont know about having too much mill? my big valves are near the edge, like the picture that boosted hatch posted up.. so is that normal?
Re: (civiclizeEg)
thanks for the info boosted hatch..
Now I feel better that all gsr heads are like mines. I was about to say that I got ripped off..
So, I got another question... Are gsr exhaust ports usually 3mm up and down?
because the guy who I bought it from clams its seen a stage 2 port but cant verify the porter or the specs. From what I seen when a head is ported the openings should look noticibly larger than before..
I compared it to the b16 head and the exhaust ports are IDENTICAL... I cant compare the intake ports because gsr and a si heads are different... Am I missing something here or did he lied to me so I would buy his head.
