Need help taking off rotor ASAP!!!
im changing my brakes and im onto the rotors and now the screws wont budge at all. i dont have an impact driver and i dont have another car or money to go buy one right now. im in the middle of it and i dont want to have to put everything back together. i have the right size phillips and a hammer and it wont move. any suggestions are greatly appreciated.
Re: Need help taking off rotor ASAP!!! (93ejay1)
Just drill the center of the screw and once you get past the head it should come out. Your only other option might be to try and heat them up with a torch or soak them in PB metal blaster. Though you will more than likly end up having to drill them out which is pretty simple. After you take it out you really dont even need to have them in there.
Re: Need help taking off rotor ASAP!!! (spoolingb20)
i didnt know you had to take any screws outt o take off rotors...i thought you just just take the 2 14mm calipers bolts off and then the 2 17mm caliper bracket bolts and then use a rubber hammer and hit that biatch off....
Re: Need help taking off rotor ASAP!!! (thaimonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaimonkey »</TD></TR><TR><TD CLASS="quote">i didnt know you had to take any screws outt o take off rotors...i thought you just just take the 2 14mm calipers bolts off and then the 2 17mm caliper bracket bolts and then use a rubber hammer and hit that biatch off....</TD></TR></TABLE>
There are those two screws between the studs.
Re: Need help taking off rotor ASAP!!! (BlueIntegraBoy)
ok so heres what i did, i put vice grips on the screwdriver hit the end with a hammer to get it in there and it turned with ease. i guess i just couldnt get a grip on the screwdriver
amej8
24
04-27-2007 05:15 PM
TheNasty0ne
19
12-03-2005 09:47 PM
Jaydeep
12
10-11-2004 03:34 PM
