water pump question...already searched
so i did an ls-v swap and noticed my gsr water pump was leaking..so i took my old b16 one..now i want to know if there both the same..because they both say 22t on them ive heard they are diff...but i counted both and they both have 22 teeth
and also it says 22t...someone back me up on this...
BTW i failed to mention that im having problems with the timing belt sittin correctly on the cam gears...
Re: water pump question...already searched (Slammed Si)
but why is that..if both water pumps have 22 teeth and are the same? unless im wrong..but they do both say 22t
Re: water pump question...already searched (hitvtecgetloud09)
Dont know the technical reason why but I've experienced it first hand plus have been told by a few people plus if you're trying to put it on and it isnt lining up that should be a clear indication that their not the same.. Get the corresponding water pump or t-belt and I'm most positive it will work
can some one clarify this information becuz i have heard that they both are the same..and i have also head they are diff...autozone says the timing belt part number is the same for both...
hitvtecgetloud09
14
07-12-2005 06:43 AM
built562
05-04-2003 07:27 PM
