Help with ITR rear seats into EK hatch
I recently bought a set of USDM ITR rear seats and have already mounted the ITR backs on my stock civic frames. I've done a search and I know many people have done this same seat swap but I can't find any decent answers to my question. My problem is with the rear bench. The metal prongs on the ITR seats do not lign up with the holes. What did you guys do to secure the rear bench?
Re: Help with ITR rear seats into EK hatch (EmoHatch)
im curious , did the bottom half fit just like the stock EK bottom, cause i thought there would be like a 1 inche gap on both sides between the seat and the molding?
Re: Help with ITR rear seats into EK hatch (JDM99Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM99Hatch »</TD></TR><TR><TD CLASS="quote">im curious , did the bottom half fit just like the stock EK bottom, cause i thought there would be like a 1 inche gap on both sides between the seat and the molding?
yes with integra seat bottoms there is a small gap on each side...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EmoHatch »</TD></TR><TR><TD CLASS="quote">I recently bought a set of USDM ITR rear seats and have already mounted the ITR backs on my stock civic frames. I've done a search and I know many people have done this same seat swap but I can't find any decent answers to my question. My problem is with the rear bench. The metal prongs on the ITR seats do not lign up with the holes. What did you guys do to secure the rear bench?</TD></TR></TABLE>
what year ITR seats are they? they should all line up just fine. do you have a picture?
I'm not sure what year they are. They're USDM though and have the plastic piece in the center so I'm pretty sure they were all the same. I'm not worried about the gaps at all.. I just want the bench secured to the car by more than the seat belts. I'll take some pics after work if you think it would help.
Re: (JOHN WAYNE)
bottom cushion of integra seats wont bolt up to ek chassis with out some modification.
easiest way would be to drill out some holes so the seat can clip into it securly.
Re: (a_kaibigan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_kaibigan »</TD></TR><TR><TD CLASS="quote">Did you remove those 3 large metal supports under the rear seat cushion</TD></TR></TABLE>
probably the worst thing you could possibly do....if you have a side impact...your car will look like a compressed accordion.
Re: (a_kaibigan)
If I removed the support there would be no way at all to secure it. Come on people.. I know plenty of people have ITR seats in their hatches.
Re: (EmoHatch)
http://www.merritr.com/seats.html
Search next time you butt mongrel.
https://honda-tech.com/zerothread?id=473617
https://honda-tech.com/zerothread?id=565874
https://honda-tech.com/zerothread?id=686769
Blah blah blah
https://honda-tech.com/zerothread?id=281316
https://honda-tech.com/zerothread?id=252542
https://honda-tech.com/zerothread?id=748235
https://honda-tech.com/zerothread?id=414831
https://honda-tech.com/zerothread?id=393722
https://honda-tech.com/zerothread?id=342295
https://honda-tech.com/zerothread?id=142908
https://honda-tech.com/zerothread?id=511701
Blah blah blah
Re: (^Jae)
Thanks for the links.. although only the one link provided any technical information.
My problem is this:
"i noticed that tabs will pop in only if you have 99-00 EK. not the 96-98 EK."
I have a 96..
Modified by EmoHatch at 10:19 AM 7/12/2005
My problem is this:
I have a 96..
305civictyperaw
13
01-06-2011 08:26 AM
Vardoulika
09-15-2005 12:10 PM
PinchE NegRo
04-16-2003 10:02 AM
