Projector Headlights
Just bought a set of Projector Headlights (Angel Eyes) for my 98 Civic Hatch, and was wondering if anyone could help me out with installing them. There is a 3 pronged harness on the back of the headlights which the bulbs are attached to (not the turn signal bulb) but there doesn't seem to be anywhere to attach the harness to in the engine bay. Also there are red and black wires (for the halo lights) that need to be connect, I'm assuming to the turn signal bulb wires, but I'm not sure. I'm wondering if there is some kind of conversion kit I need or that I'm just not seeing where to hook these up at. If anyone can help I would appreciate it. Thanks!
Re: Projector Headlights (Lofi)
Ok I couldn't find the stock harness to connect it to, I was in a hurry and was looking it over before I had to go to work. One more Question, how and where do I connect the red and black wires running out of the halo lights? Do I solder them into the parking/turn signal light wires?
Imperious: Mod of Valor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lofi »</TD></TR><TR><TD CLASS="quote">Ok I couldn't find the stock harness to connect it to, I was in a hurry and was looking it over before I had to go to work. One more Question, how and where do I connect the red and black wires running out of the halo lights? Do I solder them into the parking/turn signal light wires?</TD></TR></TABLE>
For the headlights itself, the harness you got with it.. Connect it to harness that connects into the OEM bulb in your OEM headlights. For the Halos, you're correct. You can wire it up to any power source, a switch, parking lights, whatever. Good luck.
I'm not sure but I don't think that the Projectors harness will plug into my OEM Headlight harness. I'm going from one bulb in the OEM lights to two bulbs in the Projector lights. By the looks of it I have to re-wire the whole deal, anyone know an easy way of doing this or can run me through it? Any kind of information would help me out greatly.
Thanks!
Thanks!
Try listening to the advice given.
Your stock wiring harness should plug into the new light. Yes you have only one bulb from the factory and two in the new, but you did have a high and low in the factory headlight so no issue. The wire that you unplug from the factory headlight should plug into the new one. If you are unable to find the factory wiring that was attached to your original headlights, than this is beyond your capabilities and pay someone to install them.
ASpec818
08-01-2002 09:36 AM
