So i got this b16a2 from a junkyard (need help first engine)
hello everybody.
so i just came back from the junkyard with this b16a2.
i dont know its condition so im gonna overhaule it. (not my self/in a shop)
this is my first engine that i buy so be delicat with me
please take a look in the picturs and tell me what are the components that are missing on this engine.
here is a list of the things that i know thats missing:
-DIZZY
-alternator
-throttle cable
-full engine wiring (the idiots just cut the wiring )
-engine pully.
now its your turn.... tell me if you see anything missing.
best regards moshik galimidi
p.s.
a day after i got the engine the guy from the junk yard called me and said he found the flywheel and the cluch... so i went over to take it....
are these any good?? is it of a b16?
Modified by RACEPAK at 11:29 AM 7/8/2005
-DIZZY
-alternator
-throttle cable
-engine pully.
p.s.
Re: So i got this b16a2 from a junkyard (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
i think something is wrong with the motor mount bolts, they look bent
how much did you pay, i hope you didnt pay too much cuz this thing is going to nickel and dime you to death
Re: So i got this b16a2 from a junkyard (AdamQ3B85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamQ3B85 »</TD></TR><TR><TD CLASS="quote">Tranny?
Axles? </TD></TR></TABLE>
im currently just collecting parts to complete the engine, not the instasllation/swap process.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 »</TD></TR><TR><TD CLASS="quote">Wow, great find. How much did you pay?</TD></TR></TABLE>
$630 or ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">
yeah i know that one of the bolts is bent.... but i think i can use a bolt from a D-serise.
$630 or ???
Yeah, obviously your missing tranny and axles
and if i were you i would take advantage in
installing a racing clutch while its open
your missing you distributor and your linkage
unless i missed seeing this on your pictures
but every thing else looks clean i dont know if
your wiring harness is to chewed up to re-use
though but other wise its a good start i Just
got B16 A2 AS WELL SHE RUNS GOOD .
GOOD LUCK ON THIS PROJECT. WHAT CAR IS THIS FOR?
Re: (93ejay1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">630 for a b16 shortblock with rust and cut wires? eh u could have gotten it cheaper and in better condition but hey what do i care</TD></TR></TABLE>
thats because u live in the us and have planty of them...
i live in israel..... we have maby 10 B-serise engines running around here..... so for me it was cheap.
Re: So i got this b16a2 from a junkyard (FIST321)
since hte motor is out alrdy
take out the head and check all the pistons and replace the head gasket and headbolts while u at it
Re: (93ejay1)
shortblock = complete block... no head or IM
longblock = block and head, im, basically everything but tranny
any idea how many miles are on this motor? considering hmotorsonline sells 92-95 (and u have a 94) b16a longblocks for 900+shipping and "average" 25k miles and come with a few extra parts then what you have now i'd say it wasnt a bad deal considering there arent many Bs where youre at. good luck with it
Re: (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">have fun looking for other parts </TD></TR></TABLE>
thanks for beeing so supportive. [NOT]
anyway.....
so is it obd1 or obd0?
also i have a few IM questions....
take a look....
-is that line suppost to go to the external map senor ?
what suppose to be bolted down here under the TB?
Modified by RACEPAK at 9:25 AM 7/9/2005
anyway.....
take a look....
Re: So i got this b16a2 from a junkyard (CTRwannaB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRwannaB »</TD></TR><TR><TD CLASS="quote">not sure but in one of the top pixs i think your TPS is broken :/</TD></TR></TABLE>
i know its broken but its still usable....
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">what suppose to be bolted down here under the TB?</TD></TR></TABLE>
I think its the fast idle but i might be wrong.Before its ready to go in make sure you do all the easy stuff like timing belt and waterpump
Re: (RACEPAK)
anyway.....
take a look....
Modified by RACEPAK at 9:25 AM 7/9/2005</TD></TR></TABLE>
that line on top of TB goes to the charcol canister, and by looks of it that TB is set up to use a TB mounted map, you can see to screw holes and a hole for the map tube/tip to sit in.
good luck
anyway.....
take a look....
good luck
