Is a SOHC vtec head on a non vtec block
Is a SOHC vtec head worth the money to put on a 97 4 door civic with i/e/cam gear/and 75 shot ? i already have the 93 ex tranny
Re: Is a SOHC vtec head on a non vtec block (175Shot4Door)
Have you found a head to buy? How much? If you can get it inexpensively, do it. It should give you between 10 and 20 hp. (Assuming the same power gain between a DX and an EX) I forget if it was the 1.5 with 106 hp and the 1.6 non-vtec with 115 or if the 1.6 non-vtec had 106 hp. Any back-up would be appreciated.
-Shane
-Shane
Re: Is a SOHC vtec head on a non vtec block (h22special)
im unhappy that my car weighs 3300 pounds i was wondering after i do the swap with my nitrous jet at 50would i be able to beat a 2 door 94 civic with a USDM GSR with a DC sport header and a b16 tranny ?????
your car should not weigh 3300 lbs. if it does, you have something wrong....
Anyways, yes you should be able to pull that civic
Re: Is a SOHC vtec head on a non vtec block (96turboek)
my fault i ment to say 2300 lpounds ol well i wonder what all cars i can beat with mini me swap with a fully built head and a wet 75 shot with i/h/e/cat less/?????? REMBER my car is a 4 door ek sedan
Re: Is a SOHC vtec head on a non vtec block (dadegener8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dadegener8 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
For what?
Good luck with the head install!
-Shane
For what?
-Shane
fordbronc399
05-19-2008 08:42 PM
dustywebber
07-27-2004 11:15 AM
