Head gasket???
cute little bastard
Re: Head gasket??? (CiViC_I2aCeI2)
I'm pretty sure the coolant tank fluctuates as the are gets warmer/cooler so I think you're fine.
If you don't have a shitload of white smoke that smells like sweet weirdness and no brown mud looking oil in there you should be good
You might have a small puncture in one of many coolant lines
the car necesarilly wont blow white smoke out of the exhaust pipe it all depends where the head gasket is burned up (if it is)
heres a test that might work, your car has to be <U></U> COLD! <U></U> or cold enough to take off the radiator cap. turn your car on and wait until it reaches the norm temperature, if you see a lot of bubbles coming up in the radiator its probably a bad gasket
hope this helps
hope this helps
Re: (EM1_)
well you cant really tell if theres some oil coming off the sides of the head/block until you clean it well enough and just let it idle. because the leak can be coming from somewhere else and as you drive and wind blows it can spread all around
hope that helps
hope that helps
Guest
Posts: n/a
Re: (SL_RICK83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL_RICK83 »</TD></TR><TR><TD CLASS="quote">does the upper radiator hose feel tighter than usual??</TD></TR></TABLE>
I'm not sure....Is it suppose to be tight??
Guest
Posts: n/a
Re: (CiViC_I2aCeI2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9pr »</TD></TR><TR><TD CLASS="quote"> your car has to be COLD! or cold enough to take off the radiator cap. turn your car on and wait until it reaches the norm temperature, if you see a lot of bubbles coming up in the radiator its probably a bad gasket</TD></TR></TABLE>
I can't get it to reach the normal temp, because coolant over flow (with the radiator cap off) and i didn't want it to leak all over the place.
CRuby
33
11-20-2014 11:07 AM
Si_chRis
10-17-2006 03:04 PM
