changing the fuel filter
Re: changing the fuel filter (Tealeg88)
its been covered many times.
if you do a search you will find many HOW TO about it.
*open the gas cap
*disconnect the negative (optional)
*lossen top bolt with a towel covering it, at this time make sure no way of spark
*lossen bottom bolt, gas will leak out, alot of gas
*remove the three bolt attatched to the fire wall,
*take out fuel filter from the holder thing
*put in new filter
then put back everything in reverse order.
*open the gas cap
*put in new filter
Re: changing the fuel filter (void_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by void_accord »</TD></TR><TR><TD CLASS="quote">its been covered many times.
if you do a search you will find many HOW TO about it. </TD></TR></TABLE>
I actually did try searching, but I could not find anything explaining the process.
I prefer to take out the fuel filter fuse and turn it over a couple times letting some pressure out of the gas lines. Something about filling a garage with fuel I don't go for.
Optional? I would strongly recommend this, not worth the risk when you are drenched in gas.
andrewasf77
12-06-2002 10:30 PM
