universal oxygen sensor for downstream what wires colors are what
on factory plug on 2nd o2 sensor the wires are red, white, black, black. which ones are heaters, ground, sensor(ecu)
Hold that plug up to the plug for the primary o2 sensor, and compare the colors.
2 black = heater (ECU pin A6, ignition)
white = o2 signal (ECU pin D14)
green = o2 ground (ECU pin D22)
Re: (civicious)
you need to find the original pinouts, then compare to the wiring chart given with the universal, when i did my universal i used a bosch and it had 2 grays, green, white. you just need both wiring diagrams
holmesnmanny
08-07-2012 10:55 PM
