Car leaks only when parked uphill?
Old 01-22-2006, 12:07 PM
E36 Guy's Avatar
Default Car leaks only when parked uphill?
So whenever i park uphill, theres always a small oil stain when i leave. Never there when I park on flat level. Any ideas?
Old 01-22-2006, 12:54 PM
super_nguyen's Avatar
Default Re: Car leaks only when parked uphill? (WHACK EG4)
are you sure its oil? it could be a loose oil pan bolt on the rear side, why don't you jack up the car from the front and see if it leaks again, or where it leaks from.
Old 01-22-2006, 02:11 PM
johnecon2001's Avatar
sounds like it might be a bad crush washer on the oil pan bolt.
Old 01-22-2006, 02:15 PM
JDM-97CX's Avatar
Default Re: (johnecon2001)
Both of those would leak all the time.
Look under the car and see where there is a buildup of oil. It isn't that difficult.
Old 01-22-2006, 02:17 PM
Mjeden2006's Avatar
Default Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">Both of those would leak all the time.
Look under the car and see where there is a buildup of oil. It isn't that difficult.</TD></TR></TABLE>
yeah if it only leaks when parked facing uphill check for any cracks in the back of your oil pan you might have caught a rock or something
Old 01-22-2006, 02:22 PM
eg6sir-s's Avatar
new oil pan, oil pan gasket & honda bond = no oil leaks
unless you have leaks elsewhere.
Old 01-22-2006, 02:25 PM
JDM-97CX's Avatar
Default Re: Car leaks only when parked uphill? (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">new oil pan, oil pan gasket & honda bond = no oil leaks
unless you have leaks elsewhere.</TD></TR></TABLE>
Or just look under the car and find the leak.
Old 01-22-2006, 03:10 PM
EG2Driver's Avatar
Default Re: Car leaks only when parked uphill? (JDM-97CX)
could it be a rear main seal?
Old 01-22-2006, 03:13 PM
E36 Guy's Avatar
Default Re: Car leaks only when parked uphill? (deadend9009)
I cant check because im at work, but ill check when i get home
Old 01-22-2006, 03:35 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">could it be a rear main seal?</TD></TR></TABLE>
That would leak most of the time too. Guessing and throwing parts at something doesn't fix it. He just needs to look for the leak.
Old 01-22-2006, 03:36 PM
old man neri's Avatar
Easy solution: don't park uphill
Uljima
06-03-2015 06:17 AM
uEDarkShadow
07-13-2006 07:02 PM
turbotime
12-22-2005 01:46 PM
civiccpedx
10-19-2004 01:27 PM
swlabhot
08-21-2003 04:38 AM
Quick Reply: Car leaks only when parked uphill?
