Tranny popping out of 2nd gear
I have a 95 civic ex with a dx tranny and recently it has been popping out of 2nd gear. This problem usually ocurrs when accelerating at low RPM' S and it happens atleast once or twice every time i drive. It also never happens when I am at high RPM'S.The tranny has no grinds or anything and the clutch is only 1 year old and I don't really beat on it much so I dont know why the 2nd gear synchro would be shot.
Re: Tranny popping out of 2nd gear (lawlerlaw)
check the shift linkage and check to make sure the transmission mounts are still good.
I've heard of this happening with bad mounts causing the motor to flex more then usual and having the gear pop out
Re: Tranny popping out of 2nd gear (Mr.RHTuner)
i had this happen to me. it was just occasional at first, and 2 weeks later it was constant. everytime i was in 2nd it would pop out, and the popping sometimes was very harsh (loud noise, big thump).
i replaced the tranny and all has been well, so i don't think it's the mounts. i think mista bone (guru) said that the shift fork was bent or the countershaft bearing was walking out of the case.
first thing to do is change your fluid, make sure you put the right amount in.
I would verify that the tranny has the correct amount of fluid. If it's low, then try draining and then filling with new Honda MTF.
be professional
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">countershaft bearing on the clutchside case has walked out.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lawlerlaw »</TD></TR><TR><TD CLASS="quote">I have a 95 civic ex with a dx tranny and recently it has been popping out of 2nd gear. This problem usually ocurrs when accelerating at low RPM' S and it happens atleast once or twice every time i drive. It also never happens when I am at high RPM'S.The tranny has no grinds or anything and the clutch is only 1 year old and I don't really beat on it much so I dont know why the 2nd gear synchro would be shot.
it's done for.
it's done for.
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">how do you reshim a shaft (countershaft) that doesn't accept shims?
Mainshaft and diff you can shim, countershaft you cannot.</TD></TR></TABLE>
Listen to this guy. He's a transmission guru.
Re: (aquabob89)
Here's the reason I say shims are the problem. A friend of mine reassembled an H22 transmission for me. We needed to order diff bearings for my LSD so we just put the transmission back together for the time being. For some odd reason we couldn't get the case on by like 1/2", so he removed the shim. We were lucky when we realized the transmission shifted perfect. Only problem is that 3rd would pop out if left in for a while, or at a low RPM, or when making a sharp turn at a low RPM. I know you didn't purposely remove your shim, but something as obvious as the shift linkage is almost never the issue. 90% of the time it is internal. Now Mista Bone is right, there is only a shim on the mainshaft, but is it possible that a syncronizer has flattened teeth? I don't know, I'm just trying to help.
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">Not a H22 tranny..........and if your friend put in a LSD without checking diff OAL before slapping it together, SHOOT HIM!</TD></TR></TABLE>
Whadda ya mean? Is there an obvious reason as to why the case wouldn't go back on with the shim?
D Tranny Guru
you changed nothing waiting on the diff bearings and it wouldn't go back together, so lets remove this shim, now it doesn't shift right or pops out of gear.
"Here, we don't need this........."
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">you changed nothing waiting on the diff bearings and it wouldn't go back together, so lets remove this shim, now it doesn't shift right or pops out of gear.
Well, we saved the shim, and we're tearing it down this weekend. I'm thinking he put in a synchro upside down. It just that all the forks shift fine, and all the gears are aligned. We kept the shim, so we'll see what the problem is.
Juans_MX3
04-10-2010 06:27 AM
