oil on spark plug sleeve
I am having misfiring problems with my 00 si. My car would start up one day and be fine and drive fine but then the next day it would start and sound like it wasn't running on all four cylinders and tapping the gas didn't do much. But after it would warm up it ran and drove fine.
So I put in the new plugs and wires tonight and found oil on the old spark plug sleeves from cylinder 1 and 3. After putting the new wires and plugs in it still did the same thing. I let it warm up and it ran and drove fine. But now I really don't know what to think.
Re: oil on spark plug sleeve (Michler)
replace all 4 of ur spark plug grommet thingies...only costs like 10 bux from honda...
however this has nothing to do with ur cars misfiring..throwing any codes? what kinda mods u got?
Will you make something up for me please?
What exactly do you mean by the "sleeve"? Are you speaking of the area above the threads? The ceramic portion? If there is oil there, I would first check on the spark plug hole grommets. They're probably going bad, or even missing. Pop off the valve cover and take a look.
If there is oil on the threaded area and below, then I would start to worry that maybe the rings are starting to fail.
Re: oil on spark plug sleeve (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">What exactly do you mean by the "sleeve"? Are you speaking of the area above the threads? The ceramic portion? </TD></TR></TABLE>
yah, there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote"> throwing any codes? what kinda mods u got? </TD></TR></TABLE>
I haven't checked the codes yet, I have to do that at work. I have a header, intake, fuel pressure regulator [ used to have a vortec super charger ], suspension
yah, there
dude its just the spark plug grommets...itll take u 5 minutes to replace them...
did u lower the fuel pressure back to stock after u removed the s/c
Re: oil on spark plug sleeve (Suck my DX)
did u lower the fuel pressure back to stock after u removed the s/c</TD></TR></TABLE>
yes...
tomorrow I will get new grommets and go from there... thanks for the quick responses
yes...
gixxer6
10-29-2002 01:10 PM
