removing center console on EG problem...
Old 04-18-2006, 06:32 AM
Manolo's Avatar
Default removing center console on EG problem...
im trying to change my shift boot but the two screws by the e-brake are seized. i tried to loosen them with WD-40 but they are not moving. any ideas on what to do?
Old 04-18-2006, 06:34 AM
sohcvtec1995's Avatar
get a penetrating lube. wd-40 is junk. also try not to strip the screw. if you already did then you need to notch the screw witha dremal and convert it to a flat head.
Old 04-18-2006, 07:51 AM
Crazydave's Avatar
Default Re: (sohcvtec1995)
Use an impact driver
Old 04-18-2006, 08:43 AM
gotone4ya's Avatar
go to autozone and get some PB Blaster. it is the best penetrating agent i have used yet!
Old 04-18-2006, 08:50 AM
SiYouLater's Avatar
Default Re: removing center console on EG problem... (Manolo)
Also make sure you are using the right phillips head. It should be flattened at the tip not pointy.
djscooobe
10-30-2011 10:42 PM
EusebioSam19
02-23-2010 04:23 PM
raynaud
25
01-19-2005 04:30 PM
Integra9
10-22-2003 03:51 PM
ThisLittleSleepeR
04-05-2003 05:14 PM
Quick Reply: removing center console on EG problem...
