piston / valve clearance y8 b7 mini-me
any known issues
valves & reliefs...etc...
head was milled .003
putting it on a b2 block
the cam has slightly more lift than a y8
y8 = 38.274
3-stage = 38.33
thanx
Modified by digitalcongo at 7:51 PM 4/18/2006
y8 = 38.274
3-stage = 38.33
thanx
Re: (schardbody)
stock b2/b7
y8/z6 gasket
i also have a cometic gasket but i dont know the stats on it...
i assume its the same...dont know
i'd like to use it...
y8/z6 gasket
as long as they are 4 valve pistons it should be fine, dont know many people w/ a cam in a mini me, but i would think it would be ok. you are gonna have some pretty high compression, just the mini me is going to add some then w/ the head milled, so dont forget about that. i would definately clay it first. also, not a bad idea to use some new valve springs if you arent, valve float would kill the motor and it sounds like you are gonna be cutting it close on the "quench" to begin w/.
97grnrs
12-10-2005 11:11 AM
