deck wont turn on??
deck wont turn on??
i jus finish my dash board swap to black(94 civic cx)...and i got everything to work..but my deck wont turn on?? theres power to the to the deck wires..check all fuses.. and i tryed 3 decks to see if i broke mine..im soo lost...maybe my ground wired is loose somewhere??
Re: deck wont turn on?? (jdmjaser)
there should be power to two wires, one from the ignition wire and one from the constant power wire for the memory, make sure your getting power from both or the deck may not power on. The memory one is a brown 5amp fuse under the hood of the car.
Re: deck wont turn on?? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">there should be power to two wires, one from the ignition wire and one from the constant power wire for the memory, make sure your getting power from both or the deck may not power on. The memory one is a brown 5amp fuse under the hood of the car.</TD></TR></TABLE>
thanks sir..ill go do that!!
i did not see no 5amp under the hood...but i found out wats wrong...the ground wire was not connected..behind the cluster...
jetspeedz
Audio / Security / Video
06-07-2010 07:58 AM
Hatchback of Notre Dame
02-05-2006 10:52 AM
HondaPartsHero
08-25-2003 05:29 PM
