06 si seats into an ek?
Re: (Mr. Em1)
sorry for crappy camera
I cut off all the brackets from the stock dx rails - then positioned them back in the car & connected the front 2 brackets with 1/16X1 weld steel...then did the same connecting the the rear 2 brackets. then cut off the brackets on '06 si seats (so bottom of rails where flat) & welded the rails to the weld steel
pic of custom bracket...
in the pic above you can see one little tack weld which was made with the seats in the car...the seats were then removed (with brackets attached) & thoroughly welded
cliffs - weld stock dx brackets to steel bars - then weld steel bars to bottom of '06 si rails
stock dx vs si pics
sitting at stock height too (maybe 1" lower)
stock dx vs si pics
Re: (_adirondackR_)
do you think its possible to just install them like S2000, EP, and RSX seats? just swap the seat pans. seems easier to me if its possible. don't have to cut and weld stuff.
Re: (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two »</TD></TR><TR><TD CLASS="quote">do you think its possible to just install them like S2000, EP, and RSX seats? just swap the seat pans. seems easier to me if its possible. don't have to cut and weld stuff.</TD></TR></TABLE>
thats a negative on the seat pan swap looked into that...
Re: (_adirondackR_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _adirondackR_ »</TD></TR><TR><TD CLASS="quote">thats a negative on the seat pan swap looked into that...</TD></TR></TABLE>
damn .. well the seats look good
Re: (skip.two)
damn .. well the seats look good </TD></TR></TABLE>
thank you...will have to get a better camera tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkSi »</TD></TR><TR><TD CLASS="quote">Looks like they sit somewhat high but nonethless clean seats </TD></TR></TABLE>
the backs of the seats are much bigger & slightly taller...you actaully sit slightly lower than stock
EKLowtus
04-06-2016 02:08 AM
UndisputedH22a
13
09-06-2009 10:03 PM
Red AEM Civic
01-28-2004 03:12 PM
