What engine should I put in a '99 DX Hatchback?
Here's the deal:
I already have a b17 head, and can get a '99 b20 long-block (is that the b20z?) engine for $850.
If I do a b20z block/b17 head, I'll have to chip a p28 to get it running right..
If I do a b18 block/b17 head, I should be able to use a stock, obd2 ecu right?
I'm getting lazy in my old age and thinking that a straight b18c with matching ecu might be easiest swap, as it shouldn't need anything done to it..
Anyone have any other suggestions?
Re: What engine should I put in a '99 DX Hatchback? (1point7T)
I'd say the easiest would be the B18B. Just remember, only 2000+ Acura ECU's plug directly into your wiring harness. They also come with an immobilizer though. If you go with a 99 or earlier ECU, you'll need a conversion harness but they don't come with an immobilizer. Trying to remove the immobilizer yeilds a CEL, which auto-fails you during emissions inspection if you have that in your area.
Re: What engine should I put in a '99 DX Hatchback? (EE_Chris)
Chris, I just refreshed my memory.. I forgot about the whole OBD2 A and B thing.. so my civic is OBD2B, and so are the 00+ Integras. Does this mean I could drop a 2000 LS long-block in with a matching ecu and avoid any wiring harness changes at all? Would it be completely plug 'n play as far as the wiring harness goes?
The stock axles won't work with a b-series, but the hub/spindles are fine? That's convenient.. I would just need the motor mounts, and half-shafts..
We do have e-check in this area, and I already have an OBD2 to OBD1 conversion harness that I bought when I was planning on putting a OBD1 ecu in my old car, a 00 civic si, so I'm assuming I should be able to use that, but I do realize that my current harness won't have the vtec wire on it.
Modified by 1point7T at 6:58 PM 7/26/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point7T »</TD></TR><TR><TD CLASS="quote">At this point, I can't quite afford the batmobile, but if that changes, I'll be selling rides and you'll all know.
We do have e-check in this area, and I already have an OBD2 to OBD1 conversion harness that I bought when I was planning on putting a OBD1 ecu in my old car, a 00 civic si, so I'm assuming I should be able to use that, but I do realize that my current harness won't have the vtec wire on it.</TD></TR></TABLE>
-2000 LS = plug and play
-B series axles will wok in your spindles, all b-series axles are the same, they will work
-you wont need to convert anything, and if you go to OBD1, you'll never pass "e-check"
Re: What engine should I put in a '99 DX Hatchback? (Sleepy_Red_hatch)
I've heard of people in this area passing e-check with OBD1 ecus/engines in OBD2 cars, after plugging in doesn't do anything, the tech running the test will run it on the dyno and test it as an OBD1 car.
I guess this may have changed.. but for now, I'll run the full LS motor until I get what I need to put the b17 head on.. with a 00 ls ecu, it will still pass, and they won't care.. unless i don't have a cat
Re: (Chillinlikeamofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinlikeamofo »</TD></TR><TR><TD CLASS="quote">Type R motor. You won't be disappointed.</TD></TR></TABLE>
you know where I can find one for about $2K?
Re: (1point7T)
you know where I can find one for about $2K?</TD></TR></TABLE>
a stolen one maybe
a stolen one maybe
Imperious: Mod of Valor
Re: What engine should I put in a '99 DX Hatchback? (hellxno)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellxno »</TD></TR><TR><TD CLASS="quote">sell it. buy a k20a2 </TD></TR></TABLE>
Better yet, a k24.
Better yet, a k24.
Re: What engine should I put in a '99 DX Hatchback? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Better yet, a k24.</TD></TR></TABLE>
Why not a K23A1?
Why not a K23A1?
slimjimming6688
18
11-21-2008 05:52 AM
lsvtec101
08-30-2004 06:50 AM
