Power Window Troubles. 94 EX Civic
I have read somewhere that this is a common problem but I dont recall where. I just got my 94 EX with 64k miles. Since buying the car, the passenger window has always had trouble going up, it would be VERY SLOW. Going up and down is fine for the driver window. So last night i went to roll the passenger up and it stopped 1/2 way going up and would not move. I waited a second and used the passenger button and got it up. What are my choices? For such low miles I would think this should be happening? Thanks for the help!
Re: Power Window Troubles. 94 EX Civic (Purple94EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple94EX »</TD></TR><TR><TD CLASS="quote">I have read somewhere that this is a common problem but I dont recall where. I just got my 94 EX with 64k miles. Since buying the car, the passenger window has always had trouble going up, it would be VERY SLOW. Going up and down is fine for the driver window. So last night i went to roll the passenger up and it stopped 1/2 way going up and would not move. I waited a second and used the passenger button and got it up. What are my choices? For such low miles I would think this should be happening? Thanks for the help!</TD></TR></TABLE>
Having low mileage doesnt change the fact that it has 12 year old electronics. **** ages wheher you use em or not. but anyway, sounds like you just need a new switch.
Its not the switch because the driver side has always worked rolling it up and down, just never fast. And I went straight to trying the passenger side on the 2nd attempt after it stopped so im sure its the motor. How hard is the removal/install?
Re: (Purple94EX)
I know your convinced its the motor, but at least try this. because BOTH my switches went out at the same time. find a friend with a similar EX and try his switch. if it doesnt work for sure its the motor.
