4-1 header with cat ?
Does anyone knows that if I change the header, can I still use a cat? I'm having a 96 civic 4 doors (D16Y7 engine). The stock cat is just under the hood, in front of the engine, not under the car, if I change the header, there seem not enough space to put a cat after the header.....Please help....
Re: 4-1 header with cat ? (xelloss)
you're going to have to modify your exhaust system and bolt the exhaust manifold to a cat from any normal honda that didnt have the cat-on-manifold system (i think CX/VX where the only ones to use this) and then modify you're exhaust system to fit the extra lenght, a muffler shop should be able to do it relatively cheap and a used honda cat is decently priced in the marketplace, goodluck.
Re: 4-1 header with cat ? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">you're going to have to modify your exhaust system and bolt the exhaust manifold to a cat from any normal honda that didnt have the cat-on-manifold system (i think CX/VX where the only ones to use this) and then modify you're exhaust system to fit the extra lenght, a muffler shop should be able to do it relatively cheap and a used honda cat is decently priced in the marketplace, goodluck.</TD></TR></TABLE>
I've already have modified the whole cat back exhaust...
Not quite sure what is cat-on-manifold system, any link?
EFstyle
06-18-2006 05:21 PM
ekx4
05-19-2006 09:05 AM
Kasper.
12
07-08-2002 05:38 PM
