pulled dash off now it want crank
did a quick search and didnt find any solid answers. I pulled out my dash for my cx was planning on installing ac but got lazy i installed it back but now the car wont crank when i turn the key any ideas why ???
Re: pulled dash off now it want crank (92b16si)
Sounds like you may have inadvertently disconnected or torn one of the ignition wires, I'd pull it off and look everything over to make sure. Also check over all your fuses incase you blew anything taking it off/putting it back on. From there... don't know, do you have any sort of anti-theft alarm system?
Re: pulled dash off now it want crank (Froth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth »</TD></TR><TR><TD CLASS="quote">Sounds like you may have inadvertently disconnected or torn one of the ignition wires, I'd pull it off and look everything over to make sure. Also check over all your fuses incase you blew anything taking it off/putting it back on. From there... don't know, do you have any sort of anti-theft alarm system?</TD></TR></TABLE>
just a kill switch but its not even cranking the power is there the dash is on its just not cranking
So, assuming what I read correctly the starter doesn't spin up? if it doesn't spin up and nothing happens check to make sure the starter is grounded correctly. Does the fuel pump come on? Did you disconnect the battery when working behind the dash? and if so...did you re-connect it? If the starter is NOT winding...make sure all your grounds/connections are good throughout the system. You could have a bad starter or battery, or just some funky wires.
Check your fuses first and foremost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth »</TD></TR><TR><TD CLASS="quote">So, assuming what I read correctly the starter doesn't spin up? if it doesn't spin up and nothing happens check to make sure the starter is grounded correctly. Does the fuel pump come on? Did you disconnect the battery when working behind the dash? and if so...did you re-connect it? If the starter is NOT winding...make sure all your grounds/connections are good throughout the system. You could have a bad starter or battery, or just some funky wires.
thanks everything was right i pulled the battery before i started to work on the car ill double check my grounds
alonzo_civic
02-24-2008 02:37 PM
EpicKills
01-03-2008 10:53 PM
