93 hatch
93 hatch
i am lookign at a 93 hatch with a b16a2 in it and its mycousins it was riced out by the first kid soo it has a body kit thats coming off... and the vtec is throwing a code 51 what code is that i have a integra gsr and i was wondering if my vtec could fix that one i have a b17a1
Re: 93 hatch (dets93teg)
No 51
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Re: (dets93teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dets93teg »</TD></TR><TR><TD CLASS="quote">hmm my cousin said he thought it was 51 but wats the most popular one in a vtec solenoid?</TD></TR></TABLE>
21
21
do you guys think i should get this... right now its primored and it has a front bumper and wide fenders but theyll be taken off... it has a b16a2 semi built it has new cams intake header exhaust and some other stuff done to it it runs awsome and it pulls harder than my gsr i was thinkin bout sellin my 93gsr and buyin this he wants like around 2k
Re: (BlueIntegraBoy)
i have this code right now and i took out the vtec solenoid to clean it. after installing it back on the check engine light is still on. is that a sign of a bad vtec solenoid? or is there any other reason why it is still throwing that code?
