5 Speed Conversion wiring- lil help please(don't say search!)
You've read the title obviously. Everything is done in my LS-V 5 speed swapped sedan except the shifter wiring. I have done a search so if you're gonna imply i do a search, search for another thread to post ***** on. I've looked for 5-speed conversion, auto to manual swap, auto to manual conversion and a **** ton of other topics to search on and nothing with the wiring has come up that was worth more than two ***** full of corn in a brown bag. Someone please give me some insight here on what has to be done to the god forsaken shifter wiring. I do not want to fuckwad rig the **** with the stock shifter assembly slider. Thats gay. Don't give me the bullshit of, get a manual. Someone here has done the wiring the right way and documented it. If you're that person, post here. If you know where that person posted, post here. Otherwise, i dont feel like listening to you bitch and moan about how many times you've seen this thread. In the time you'll take to write that, you could have found the thread that you've seen a million times that tells people how do to this.
Thanks bitches.
Thanks bitches.
Re: 5 Speed Conversion wiring- lil help please(don't say search!) (the4g4d)
SEARCH
i did and found this....so try harder next time...
Wiring!
"Now this is pretty easy, but then again i love electrical. But all you need to do is connect 5 wires total. One of the plugs that you disconnected from the auto shifter is a 14P plug. Cut the plug off. Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car. Important
Next there is a yel/red wire and a grn/blk wire. Doesnt matter what way they go they do the same. These are for your reverse lights. Connect some line to them and run it through the firewall to your reverse light switch. And your set. "
taken from Luserkid's auto to manual thread "[FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics)"
https://honda-tech.com/zerothread?id=1337459 for more info
Wiring!
Ls_V_TurboSi
02-18-2006 07:49 PM
Moemers
11-07-2005 05:22 PM
Riceburn'nGreg
05-04-2005 04:12 AM
