GSR brake/supension swap
All 94+ integra brakes (minus itr) are the same....
If you have the ex/si/abs knuckle (10" rotors) the calipers bolt right on.
All rear disc parts are identical (minus da/ef which have larger bushings)
Search in places other than the FAQ, this has been coverd again and again and again
Re: GSR brake/supension swap (BlueIntegraBoy)
Yes you can. Just keep the EK upper control arms in the front. I think thats what they are called. It holds the top ball joint for the knuckle to bolt in. Make sure you use the EK one. I just did this and it worked perfect.
sj-performance
07-14-2009 07:55 PM
lowgman
01-16-2005 07:19 PM
ncVTEC1313
06-03-2004 05:14 PM
