what ecu???
Check Engine Light.
the code the the MAP sensor....
I'm guessing you're looking for a different ECU because the car runs crappy with the one you have.
But MAP codes will make the car run crappy, so diagnosing the MAP code may fix your problems.
Re: (what1118)
check vacuum lines, i had the same issue as far as the map sensor cel code, ran like **** with no vtec, then i replaced some fittings on the lines/reset the car by undoing the battery terminals for about 10 seconds then put it back on, if the cel code continues then locate the sensor and troubleshoot it from there, check all of the lines, cracks, holes, anything in the vacuum lines from the map sensor. it could be something very minor
JDMxJEDI
05-04-2008 04:38 PM
