d15b5 engine code what car is it out of?
my friend might give me a swap with that motor... but i searched and found nothing anywhere about it. any info would be sweeet
[edit] D15B4
Found in:
1989-1991 Honda Civic GL (Australian Market)
Displacement : 1493 cm³
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 90 hp (70 kW) @ 5200 rpm & 122 Nm @ 3800 rpm
Valvetrain : SOHC (2-4 valves per cylinder, depending on year)
Fuel Control : Dual Carburettor
[edit] D15B6
Found in:
1988-1991 Honda CRX HFx
Bore and Stroke : 75 mm X 84.5 mm
Compression : 9.1:1
Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf @ 2800 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
according to wikipedia (dont know how true that is, but it may help you), nothing on a b5 though.
http://en.wikipedia.org/wiki/Honda_D_engine
Found in:
Compression : 9.2:1
[edit] D15B6
Found in:
Compression : 9.1:1
The D16B5 motor is the CNG motor (compressed natural gas). has 12.5:1 compression with a 90mm stroke, 137mm rod, 75mm bore. I found this info here:
http://bensebuilt.livejournal.com/2006/09/06/
Civic GX
Modified by JShull at 7:13 AM 12/21/2007
Civic GX
