B20 automatic swap.....into DC question about switching throttle bodies....
it's 1995 integra with a jdm b20 swap, it is an automatic car. On the t.b. it has a extra throttle cable going to the tranny, now from what I researched that helps the car shift so if I remove it, it will either not shift or will shift to hard.
my question is she has a Skunk2 intake mani already on there, she wants to put the tb on there to so how would I either delete this extra cable or add it to the SK2 one..? thanks for the help..
the only thing I could think of is take the bracket that holds the throttle cables which opens and shuts the butterfly and switch them, but the sk2 one is different...
Re: B20 automatic swap.....into DC question about switching throttle bodies.... (4gencivicef9)
if its an automatic, you need that 2nd cable. just take the butterfly from the stock and put it on the new throttle body
Re: B20 automatic swap.....into DC question about switching throttle bodies.... (fmrprojects)
well I cannot take the acutally butterfly cause the stock one is 52mm and the SK2 one is 68mm so I have to switch brackets I guess...thanks
2fastss
08-07-2009 11:44 PM
