motor problems
motor problems
I hve a 94 civic with a gsr out of a 97 integra and as far as i can see the only mods are a vafc1 i was driving the other night and my buddy switched the sensor type and my car died so i looked into it further it burnt 1 plug and fowled the rest so i bought new and finally got the car started and now it has a tic in the lower end does any know maybe what happened it also has a 4 wire o2 and a 1 wire o2 the 4 is hooked up but the 1 is not could that be a problem
Re: motor problems (94civicgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicgsr »</TD></TR><TR><TD CLASS="quote">I hve a 94 civic with a gsr out of a 97 integra and as far as i can see the only mods are a vafc1</TD></TR></TABLE>
You just identified your problem. That and your buddy shouldn't have messed with ANYTHING on the VAFC(junk) while the car was running. Slap him next time you see him and ask him if his mother taught him "if its not yours, don't touch". If your injectors ended up dumping fuel into the engine, that would explain the fouled/burnt plugs, and it could have washed down the cylinders, creating your "tick". Thats just a guess, but find out as much as you can about what the car is doing before proceeding with more questions.
And no, the rear or downstream O2 is just there to monitor catalyst efficiency, and really doesn't have much to do with adjusting fuel trims.
Re: motor problems (King V)
the problem is with the VAFC junk it or sell it to a newbie, find someone to chip your ecu if you need it and tune it for you.
i was guessing that the tick is coming from the rod or main bearings but i dont want to tear into the motor without being sure if that is the problem. and the one wire o2 sensor will not affect my car from performing properly. and when i rev it high my cel comes on and it redlines at 6000 i was wondering what could be the problem to that but if i shut the car off and turn it back on the cel goes off and the car runs fine till i rev it high again
crxhybrid1320
02-10-2004 04:20 PM
crxhybrid1320
02-08-2004 06:46 PM
1fstevo
10-30-2001 10:13 PM
