B16 OEM injector cracked, would 310 cc injectors make the car run rich?
i found out that one of the oem b16a injector is cracked. i can get a set of used rc 310 cc injector for real cheap. car is n/a with some bolt on. air intake. header.exhaust. bigger throttle body and intake manifold.
would 310 cc make car my run and idel rich or any problem?
thanks
thanks
Re: B16 OEM injector cracked, would 310 cc injectors make the car run rich? (SkoundrelUSA)
I have oversized injectors in mine with high pressure fuel pump and regulator and I am still running lean, working on the ecu right now, I think you will be ok, better rich then lean
Re: B16 OEM injector cracked, would 310 cc injectors make the car run rich? (venomzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by venomzz »</TD></TR><TR><TD CLASS="quote"> better rich then lean</TD></TR></TABLE>
Until you wash your cylinder walls.
cute little bastard
Re: B16 OEM injector cracked, would 310 cc injectors make the car run rich? (Powered by VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">so, not ok to run 310 cc injectors?</TD></TR></TABLE>
no def not. Look around for stock ones. Easy to find. I have a set of VX ones but I'm not sure if they're 240cc
Go to the junkyard and grab a set out of an Integra, all B-Series injectors are the same. Doesn't matter if it's an Integra LS or a JDM Type R or even CRV. Just make sure you get them for what ever OBD you are or plan to run.
Re: (tougeR)
Aren't the stock 240cc injectors pretty much done about 150hp?
Seems reasonable with some bolt-ons that something bigger "might" be needed.
I'm just using this link as an example.
http://www.witchhunter.com/injectorcalc1.php4
Not my area, I'd like to learn it.
atarigamer01
10-30-2008 06:39 PM
JDMB20TDA
08-28-2007 06:07 PM
arsenaldragster
04-22-2003 07:09 PM
