b18c1
Old 01-19-2008, 09:20 PM
`chrisb's Avatar
Default b18c1
I was wondering, I know with the p72 ecu u have to wire the iab, and knock sensor up. But if u chip ur p28 will u have to do them things?
`chrisb is offline
Old 01-19-2008, 09:25 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: b18c1 (`chrisb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering, I know with the p72 ecu u have to wire the iab, and knock sensor up. But if u chip ur p28 will u have to do them things?</TD></TR></TABLE>
No. The P28 has no input/outputs for the IAB or knock. So you can leave those out.
B serious is offline
Old 01-19-2008, 10:12 PM
`chrisb's Avatar
Default Re: b18c1 (B serious)
Alright and the engine will not throw any codes using the chipped p28?
`chrisb is offline
Old 01-19-2008, 10:14 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb &raquo;</TD></TR><TR><TD CLASS="quote">Alright and the engine will not throw any codes using the chipped p28?</TD></TR></TABLE>
The ECU throws codes. Not the engine.
Old 01-19-2008, 11:44 PM
ekb16's Avatar
u should change the stock gsr IM if ur gonna use a p28
ekb16 is offline
Old 01-21-2008, 08:44 AM
B serious's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">u should change the stock gsr IM if ur gonna use a p28</TD></TR></TABLE>
Or just undo the vacuum line for the butterflies so they're always open.
Old 01-21-2008, 09:04 AM
`chrisb's Avatar
Default Re: (B serious)
From what i got so far i got the a20 pin switch to the a17 pin on my ecu thats done, then i cut my knock sensor off the gsr harness and add to it my z6 harness on plug d for the shock tower, then i add a wire from plug d through the firewall to d3 on the ecu plug .. Is that all ?
`chrisb is offline
Old 01-21-2008, 09:50 AM
B serious's Avatar
Default Re: (`chrisb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb &raquo;</TD></TR><TR><TD CLASS="quote">From what i got so far i got the a20 pin switch to the a17 pin on my ecu thats done, then i cut my knock sensor off the gsr harness and add to it my z6 harness on plug d for the shock tower, then i add a wire from plug d through the firewall to d3 on the ecu plug .. Is that all ?</TD></TR></TABLE>
Yeah. That sounds like all the wiring mods. However, why did you have to switch the A20 pin to the A17 pin? Your car allready came wired with VTEC and with a 2 wire IAC.
I believe the A20 to A17 pin switch is for 96-00 non ex/si models that have the 3 wire IAC, IIRC.
Old 01-21-2008, 12:51 PM
`chrisb's Avatar
switched the a20 pin cause ya dont use it on the gsr motor and put it in a17 for the iab.
`chrisb is offline
Old 01-21-2008, 03:46 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `chrisb &raquo;</TD></TR><TR><TD CLASS="quote">switched the a20 pin cause ya dont use it on the gsr motor and put it in a17 for the iab.</TD></TR></TABLE>
What does the A20 correspond to? You dont have an IAB function on the P28, though. You might as well have just left that alone....
Old 01-21-2008, 05:07 PM
`chrisb's Avatar
i know im not using the p28 no more im using the p72 ahah
`chrisb is offline
MOVE OVER
09-06-2007 08:59 AM
streetracerof06
10
12-29-2005 06:14 PM
EJ1_203
07-23-2005 04:48 AM
B2FiNiTY
05-05-2005 04:33 AM
IdotheSHOCKER
05-30-2002 09:42 AM
Quick Reply: b18c1
  • Ask a Question
Question Title:
Description:
