Need Help... GSR brakes fit on 2000 civic hx ?
Will GSR brakes fit on a Civic hx?
"""GSR front knuckles
-needs lower ball joints
-5k on new rotors and pads
-stainless steel brake lines
GSR rear disc complete
-not sure on rotors and pads will update
-comes with e-brake cables
little rusty but will wear off once driven on """"
is whats on craigs list $400
is that good?
will it fit easily on my civic?
what parts will I need?
will I need new axels? if so which ones?
any tools I need? will they clear my hx rims?
those are 14inch alloy hx rims....
thx for help.. need quick puchase..
Anyone have any rear disc brake swaps for civic?
is that good?
Re: Need Help... GSR brakes fit on 2000 civic hx ? (Ahmad ibn-Fadlan)
Yes they will fit. I have GSR brakes on my del sol and i love them.
It'll all bolt up.
You'll need Civic si e-brake cables.
You can use your stock axles.
I'm not sure about them clearing your hx wheels. My baby fat fives barely clear. (also 14's)
It'll all bolt up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahmad ibn-Fadlan »</TD></TR><TR><TD CLASS="quote">whats the down side to 5mm spacers?</TD></TR></TABLE>
You'll have 5mm less of threads to tighten your lug nuts. If they're torqued properly (80 ft/lbs) you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahmad ibn-Fadlan »</TD></TR><TR><TD CLASS="quote">Any plus?</TD></TR></TABLE>
You'll be able to use your HX wheels, but you could also grind a little off the brake calipers.
Re: Need Help... GSR brakes fit on 2000 civic hx ? (Ghetto Civic HX)
Are the front and rear the same story?
or do the rear fit with out modification?
how much do you have to grind off?
which is the best way to go about grinding it? how do you know where to grind and how much?
I assume if you grind to much off you ruin the caliper....?
I'm pretty positive that with the rear you don't have to do anything. I assume that since you would need a 5mm spacer for the wheels to fit you would need to grind off 5mm. You would grind on the outer most point. I'd think that a normal angle grinder would get the job done. Its likely a trial and error sort of thing. Grind a little bit. Test fit the wheel. Grind some more if needed. I've never done it before so don't know for sure. This is all my assumptions.
I wouldn't grind 5mm (nearly 1/4") of material off anything in my brake system. I did this complete 4-corner GSR brake swap on my 98 hatch. As was mentioned you need 99-00 Civic Si e-brake cables, and I used the Si stainless lines also but I can't say for certain that the GSR ones included with your package won't work. Your stock proportioning valve is good. You may consider changing the master cylinder to a larger one but if you are still sohc leave the stock booster on.
Otherwise it all bolts up real easily, no mods. Price seems OK.
Re: Need Help... GSR brakes fit on 2000 civic hx ? (Bob Dole!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! »</TD></TR><TR><TD CLASS="quote">Yes they will fit. I have GSR brakes on my del sol and i love them.
It'll all bolt up.
I'm not sure about them clearing your hx wheels. My baby fat fives barely clear. (also 14's)</TD></TR></TABLE>
is it a must that you get SI ebrake cables when doing any gsr rear disc conversion on any 96-00 civic no SI's? Why can't you use the stock gsr ebrake cables it they came with the conversion?
It'll all bolt up.
