can someone tell me why these 2 d16y8's are different?
I am pulling a blown motor out of a 99 2 door ex, and the motor that is in there has two different things the other one doesnt. 1 is a coolant line, but I dont know why they would be different. On the new engine there is the 2 bigger main hoses and on the engine that is in the car now there is 2 bigger ones and 2 smaller ones. The other is a blue sensor in the back of the block, im sure it will throw a code because its not plugged in and there isnt even a spot on the new engine for it to thread in.
Re: can someone tell me why these 2 d16y8's are different? (94b16teg)
what year motor is the other y8? is it from like a 96-98? the blue plug is a knock sesor for sure though...but i know the hanresses are different on the knock sensors...so you will have to switch the narness from the other motor
Re: can someone tell me why these 2 d16y8's are different? (jr000)
your blue sensor is definitly a knock sensor, all y8 engines had the knock sensor. even the y7 block had the threads for the KS but you must not have 2 y8 engines there. the hoses are like that because one is a newer y8 engine and honda changed the design of a few things in 99-00. the other must be 98 or older, dont know why
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie31003 »</TD></TR><TR><TD CLASS="quote">most likely you have a jdm engine and a usdm one, one has a set up for emissions and one doesnt.</TD></TR></TABLE>
There is no jdm version of the y8, they were only produced for the US.
Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IanB »</TD></TR><TR><TD CLASS="quote">'96-'98 = OBD2a
'99-'00 = OBD2b</TD></TR></TABLE>
Different on the coolant hose you just showed
Well this is what I found out. I was doing this swap to help a friend. He found the engine and picked it up. When he came the motor was pretty complete it had intake manifold and dizzy, and exhaust manifold. The intake manifold is from a y8 so I honestly didnt look at the motor much further. Then I started noticing the differences like the water neck and no knock sensor then I realize this is a d16z6 with a y8 manifold. I got a d16z6 a while back in great running order for $250 and my buddy paid $550 for this one. I guess next time ill look at the engine code first, it just through me off with the y8 intake.
nytosc
11
09-18-2011 09:44 PM
