oil leak
Re: oil leak (nemesiskrp)
Its kind of hard to tell where you really pointing to. Is around the distributor? It could be the dizzy o-ring then. Almost looks like oil is all over the front of the head, might be the valve cover gasket then.
By just looking at the pics provided I can safely say that it is definately a combination of a valve cover gasket/distributor seal.
If you decide to replace them yourself make sure to use some Hondabond where the service manual/Haynes manual reccomendeds
Good Luck!
Good Luck!
Re: oil leak (z6hatchboy)
ya its not like leaking on the ground or anything just a lil bit down from the valve cover and on the left side. does it look bad???
Bad really depends on how much oil you have to add to it ever week or so. But no oil leak is a good one. The dizzy o-ring is $2.00 from honda, and you can get a fel-pro valve cover gasket from your local auto parts store for around $20 i think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesiskrp »</TD></TR><TR><TD CLASS="quote">you think it would be hard to fix the leak?? est the time and money on the parts?? thanx</TD></TR></TABLE>
Its not hard at all, time for you to do these i would est. 30 minutes.
k kool thanx...ya i havnt had to put any oil in since november and i checked my oil today and im a quart low... so i figured id fix that and do an oil change.... any thought ons the purple oil?? i dont know what its called??? my motor prolly has 50,000 to 60,000 on it?????
Re: oil leak (redcoats1976)
ya i think it might be the vtec solenoid as well.... i duno the oil dosnet loook like its comin from any one spot you know.. its kinda all over in that area..but was it hard to fix the solenoid????
Civiccity03
07-17-2017 04:54 PM
DCAR
14
06-24-2012 11:12 AM
