Clutch Slave Cylinder?
Alright, how hard is it to install a clutch slave cylinder in my del sol? I have a D15b7 motor, would i need to remove my tranny in order to install the new one?
Re: (vtec2late)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec2late »</TD></TR><TR><TD CLASS="quote">slave cylinder sits right in front of the tranny. 2 bolts 12mm wrench.</TD></TR></TABLE>So basically its self explanatory? I just want to make sure its not a hard thing to do lol, I have no time for my tranny to be taken off..Anymore info, would be kindly appreciated!!
Re: (PinoyDelS0l)
All you have to do is remove the one on there, and replace it with the new one. VERY straight forward job. 2 bolts get it off the tranny, remove the hydro fluid line, reverse and bleed the clutch. You are good to go.
Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">All you have to do is remove the one on there, and replace it with the new one. VERY straight forward job. 2 bolts get it off the tranny, remove the hydro fluid line, reverse and bleed the clutch. You are good to go. </TD></TR></TABLE> I just did that a couple of minutes ago lol. Thank you though! I should haved looked before i posted something stupid like this lol. Thank you!
garyhgaryh
07-21-2007 03:05 PM
ApolloSpeed
02-12-2006 12:51 PM
