SI cluster MPH messed up
ok so i have a 99 civic EX and i jus got a SI cluster i was able to match up the miles and get everything all set up...but when i put it in my car and started it up the MPH needle jumped to 25mph and stayed there! aside from that the cluster works fine the MPH needle does move and seems to give an accurate reading of the mileage aside from the fact that it is 25 over...does anyone know how to fix this problem so it stays at 0?!?!
ooh yeah when i shut the car off the needle drops back down to 0. thanks for any help!
Re: SI cluster MPH messed up (SpeedoKing)
i have been doing some thinking and i am going to install the cluster without the clear plastic shield over it so i can touch the needles and then the car starts and the needle jumps to 25 i was jus going to push the needle back down to 0 and hope that it will stay there. can i do any damage doing this??
Re: SI cluster MPH messed up (BlueIntegraBoy)
thats what i did and it worked thanks man but i think that the speedo is not calibrated right b/c it seems to be reading a faster speed than what it should do you by any chance know where i can get that fixed or how to fix it?
Re: SI cluster MPH messed up (Jdmglenn)
ok well i am going to try and get help form a shop that specializes in gauge clusters and repairs. if i find anything out i will let you know....does anyone else have this problem or know how to correct it? any help or pointers will be GREATLY appreciated.
1999jdm
11
04-17-2013 04:22 AM
kaboomwoom
03-12-2008 01:06 AM
JSPECEX
03-23-2003 07:53 PM
