Piston Pin Installation & Removal Help - JINOTIQ...
Ok im currently rebuilding an LS (B18B1) motor as a temporary
my questions are:
1. Is there a way to remove the PISTON PIN without the use of any hydraulic tools?
2. If yes/no, Does anyone have any experience running PR3 pistons w/ PR4 rods in an LS, and what other modifications are necessary in doing this; considering everything is stock?
All responses/opinions/tips/criticism/recommendations/experiences are welcome!!
P.S. I've searched literally everywhere on this topic, if you find a link regarding this for a HONDA, I will be really embarrassed!
my questions are:
Re: Piston Pin Installation & Removal Help - JINOTIQ... (jinotiq)
A hydraulic press works most of the time but there is a chance of breaking something. I don't think you can do it without a press or heating it up really good. I always wanted to try and find an easier way but i doubt there is. I was gonna try freezing the pin so it contracts and see if it can be pushed out easier.
You have to use a press... Its why theyre called "pressed pin" pistons
Although:
https://honda-tech.com/zerothread?id=1003502
Although:
damnn i wish honda could have tha snap rings holding tha pin in like nissan does
looks like thats tha only thing i have to go to tha machine shop for then,
stock honda pins need to be pressed out but i've heard that after market ones have a pin that holds everything together.
Re: Piston Pin Installation & Removal Help - JINOTIQ... (slacks)
ok so far, i asked an old man and he said my pistons are aftermarket beacuse there was space between tha rod and piston across tha length of tha pin, but my argument was no way, because both parts both say pr3
could aftermarket parts use those numbers on their parts
Why dont you just look for pictures of oem piston and rod sets for comparison.....?
here, I already found you a couple good ones....
http://www.hondamarketplace.co...97812
https://honda-tech.com/zerothread?id=2214515
Do they have locks on the outside of the pin?
No?
Then theyre factory Honda pistons.
No?
Re: (IslandSi)
ive looked for pictures from my service manual and other websites with pictures, and tha pins look jus like little round cylinders. i expected like a groove or something in tha center, but nothing! ah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">you probably didn't find anything when you were looking for Piston Pins because they're actually called WRIST PINS.</TD></TR></TABLE>
oh and i searched for "piston pins" "wrist pins" "rod to piston connecting pins" jus about everything
im gonna ask power pros
Re: Piston Pin Installation & Removal Help - JINOTIQ... (tdizz07)
yess, thank you, finally
um, how much did they charge you by tha way
andd how do you like em
they charged me 8 each piston they put it on (4*8=36)
i havnt got the motor together yet but should be sweet
im actually doing pr3 rod w pr4 piston for turbo.
but it should be sweet.
but i left the ls rods empty if i woulda got the cracked ones put on em(woulda been stupid) it woulda been 36 more
ha, thats funny, im doin exactly opposite.
im gonna use pr4 rods and pr3 pistons, and for n/a
jinotiq
21
06-30-2008 07:44 AM
00siBuilder
19
03-24-2004 01:28 PM
