How do you take off your steering wheel?
Old 06-25-2008, 01:15 PM
Civic_07's Avatar
Default How do you take off your steering wheel?
I have a 93 Civic EX Coupe...I want to take my old steering wheel out and put in a new one (Because the airbag blew, and it just looks ugly)...Can someone tell me the step by step process in doing this? And does any steering wheel from a 92-95 Civic fit? Lastly, does your SRS light go off once you put a steering wheel with an airbag that hasn't blown.
Old 06-25-2008, 02:13 PM
hard_boiled_EG's Avatar
Default Re: How do you take off your steering wheel? (Civic_07)
correct me if my wrong...but i'm pretty sure i got all the step..this is just off the top of my head.
1. remove the + terminal off your battery
2. underneath your steering wheel there's a little cover, take that off and there will be a little yellow clip, unplug that.
3. then to the left side of the steering wheel there's another cover, take that off and there will be a star key bolt, take that off.
4. to the right side there is another cover take that off, and there will be a black cover under that, there is 2 screws holding that down, after you take that off there will the the star key bolt, take that off.
5. your airbag should come out now.
6. there's all kinds srs plugs and crap behind the airbag, unplug and remove all of them.
7. there is a 19mm nut in the middle remove the nut and your steering wheel should slide right out if your lucky...if it doesn't slide right out either pull REAL hard, or go rent a steering wheel puller from autozone...
hope this helps..
Old 06-25-2008, 04:27 PM
Civic_07's Avatar
Im getting the steering wheel from the junk yard, what do you mean the airbag should come out?...you meant it should inflate? or just the airbag section? Thank you
Old 06-25-2008, 04:44 PM
RunninEg6's Avatar
he's describing the process to take out the airbag section so that u can get to the nut that holds the wheel to the column
Old 06-26-2008, 09:36 AM
Default Re: (RunninEg6)
x2
Old 06-26-2008, 12:23 PM
Civic_07's Avatar
ty
jnb0111
12-28-2015 04:23 AM
crazyhouse2011
21
04-25-2013 05:58 PM
gsr_b20b
06-20-2010 08:47 AM
qwrty
10-29-2009 01:55 PM
Civicdrgrcr
09-23-2002 03:03 PM
Quick Reply: How do you take off your steering wheel?
