swap question eg d15
Re: swap question eg d15 (hpmx18)
i double checked that also and its still doin the same thing, all fuses are ok grounds are ok im thinkin its sum small lil **** i just have no idea wat
Have you checked maybe the fuses? There is this one fuse under the panels that won't let your car start no matter what if its burned. Should be next to your srs with a yellow cap on it. Try that. That's all I can think of right now.
Re: swap question eg d15 (mortificationrock)
oh, i got it. You have to loop the wires together that go into the old shifter box. It is a kill switch. Im not sure how to do it but it is done on my car. I can take a picture for you but i won't be able to post it til tomorrow.
Re: swap question eg d15 (Ploeg8393)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JEGD16Z6 »</TD></TR><TR><TD CLASS="quote">the connector for the PRNDL should have two big wires on the bottom. jump the biggest wires on the bottom of the connector. </TD></TR></TABLE>
i know which wires your talkin bout the black-white n blk-red that goes 2 the starter from the ignition, i allready have them taped 2gether thats wat make the car turnover it just wont start,
imm stop buy there 2day and switch out the computer with my old p75 and hopefully it was the computer cause im out of ideas and things 2 check
Xgen
19
08-12-2005 10:31 AM
