need help adjusting stiffness in my clutch
Old 06-24-2008, 01:58 PM
allshownogo's Avatar
Default need help adjusting stiffness in my clutch
how do i make my clutch stiffer? its hydraulic.
Old 06-24-2008, 02:14 PM
1CaMw0nDeR's Avatar
Default Re: need help adjusting stiffness in my clutch (allshownogo)
Bleed the system until theres 0% air bubbles coming out, than bleed it one more time...
You can also adjust your clutch pedal up under where ur pedal is at, theres a nut on a bolt that holds ur clutch pedal from going to far forward and backward, adjusting that sometimes makes it seem a bit stiffer...
Old 06-24-2008, 04:06 PM
ej2man's Avatar
possibly a stage 2 pressure plate. correct me if im wrong
Old 06-24-2008, 04:27 PM
Resident Gearhead
BryanM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allshownogo &raquo;</TD></TR><TR><TD CLASS="quote">how do i make my clutch stiffer? its hydraulic.</TD></TR></TABLE>
Stiffer like it used to be? Stiffer like it should be? Dun get it.
If it isn't as stiff/hard LOL as it sould be a bleeding is in order. Next I would question the slave cylinder and next the clutch master cylinder.
Orignial clutch?
Old 06-25-2008, 12:06 AM
obuhmyuh's Avatar
Default Re: need help adjusting stiffness in my clutch (mcvtec)
upgrade your clutch/pressure plate.
Stonage07
03-06-2017 11:48 AM
crazyguy
06-08-2007 01:16 PM
LSEGHATCH
05-02-2006 06:18 AM
B-SerioUs EGg
12-22-2005 03:42 PM
Jeffrey9
11-29-2005 02:57 PM
Quick Reply: need help adjusting stiffness in my clutch
