VSS issue
VSS issue
I have a USDM ITR gauge cluster in my 92 hatch, the speedo has always been off. It seems to be sort of an increasing amount as my speed raises, leading me to believe its some sort of a signal issue. I also wondered if maybe it is because I am using a D series trans with a D series VSS instead of the B series that would normally be associtaed with the ITR cluster.
I am in the process of an H2B swap which would give me the B series VSS so if this is going to work then no worries, but if not is there any way to adjust or fix this problem? Thanks in advance
TheoneTheycallVille
03-01-2009 11:29 AM
turbociv910
01-26-2009 09:17 PM
