brake problems
brake problems
k i put rs integra master booster on the ride today and for some reason the front left wheel locks up bad ,just that wheel though, and when it happens it pulls real hard that way. could the caliper went bad ? any thoughts appreciated
Re: brake problems (blackccoupe)
Bad master cylinder my friend.... Suprised u didnt see sparks showering the road when it locks up... "Happened to me twice".... BaD M/C FTW..!!
Re: brake problems (1CaMw0nDeR)
the booster and master are new one master was bad so i got another one from pepboys and it worked fine til i drove the car lol how would a bad master cause the one wheel to lock up ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe »</TD></TR><TR><TD CLASS="quote">anyone</TD></TR></TABLE>
because it's not sending out the correct PSI...
and if that's the case i'd return it to pepboys and tell'm you want an exchange... this has happened to me not only once, but 3 times "between myself and a friend" and everytime all we did was change the master cylinder, bleed the brakes, and it went away... I was runnin gsr front an rear brake setups on my coupe and was relying on the stock proportional valve every time an i just kept goin thru master cylinders until i picked up my 91 ex sedan 15/16 m/c than my brakes were glorious...
yeah i have the 4040 valve i just dont want to go through taking the master back off and putting a new one on if that isnt the problem
i adjusted th booster rod to stock specifations but for some reason when putting the master cylinder there was about a 1/4" gap from the master to the booster i had to push it on to go on like the rod was already pushing the master could this be causing my probelm?
hmmm, you shouldnt really have to had adjusted it at all... well if ur M/C isnt faulty i can bet you the problem relies within ur m/c somehow or another... ie - pressure possibly not being enough....
just ran the # on the brake booster box the idiots sent me the abs one wtf know i know why all these weird problemsa are thanks though guys
k got the right booster let me tell you goign from the stock booster and ex 15/16 master to the integra setup is night and day wow brakes work way better
zccrx
09-04-2008 08:45 AM
Nisif
12
08-20-2007 01:14 PM
I_love_my_HONDA
04-24-2005 07:34 AM
