Wheel studs, spacers, Lugnut?
Alright, well im going to be replacing all 16 of my wheel studs since i cross threaded all of them with the wrong wheel locks. Now my question is, do you think the Blox Extended Wheel studs are good choice to use for my Del sol? Heres a link... http://jdmultimate.com/blox-ra....aspx
And what kind of wheel spacers would you recommend? And do i need to also purchase a new set of lugnuts as well? Alright thank you!
You managed to cross thread all 16 studs? Holy crap.
If I were you I'd go with OE studs from a dealer, and just get some lug nuts at a tire shop. Then you dont have to bother with spacers.
Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">You managed to cross thread all 16 studs? Holy crap.
If I were you I'd go with OE studs from a dealer, and just get some lug nuts at a tire shop. Then you dont have to bother with spacers. </TD></TR></TABLE>Yeah i pretty much cross threaded all 16 ... But i want to add wheel spacers for my car to give it a better stance. So do you think if i buy OE studs at honda, theres wheel spacers out there that is capable of working with the OE wheel studs? Or do you think i have to buy extended wheel studs???
If you're going for stance, then I would recommend longer studs, just search and find a company with a good reputation. You don't want your wheels falling off.
Re: (OMGWTFBBQ!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMGWTFBBQ! »</TD></TR><TR><TD CLASS="quote">If you're going for stance, then I would recommend longer studs, just search and find a company with a good reputation. You don't want your wheels falling off. </TD></TR></TABLE> Yeah, i already found a good company. H&R.. They also done me right with there products. So would i be able to use my OE studs for the wheel spacers? Or would i also have to buy extended wheel studs????
Re: (hoo my gosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoo my gosh »</TD></TR><TR><TD CLASS="quote">depends how big of a spacer you want. you can get away with 6mm spacers on stock studs.</TD></TR></TABLE> How much does my tire stick out if i do 5mm? I was planning on doing 15mm...
Re: Wheel studs, spacers, Lugnut? (demian22)
Well i decided on a conclusion, and im no longer doing wheel spacers since it seems a bit unsafe. So im just going to buy some OG Wheels with a +25 offset so that my wheels will stick out a bit. And im just going to use extended lug nuts.
gakkuken
21
01-10-2005 02:28 PM
