HELP, MY EX TACH isn't working!!
How's it goin guys, got a bit of a problem. I recently removed the white facing of my '98 EX tach that my brother put on there and when I did, the back light wasn't lighting up at first. So i replaced the bulbs and it still didn't work. Then as if that wasn't bad enough, now the whole tach doesn't function. The RPM isn't working anymore, the speedo isn't moving, the gas and temp gauges are far off. I'm really hoping that it's repairable cuz i'm new to modifying things but i'm willing to learn how to fix it. Anyoen got any tips/tricks/help?
Re: HELP, MY EX TACH isn't working!! (RCurioso88)
id u remember to plug the harnesses back in? that might b the problem, u forgot a harness. Also, u might wanna check ur fuses under the dashboard. Maybe you blew something.
Re: HELP, MY EX TACH isn't working!! (koolkevin1107)
fuses would be my first place to start. after that, make sure its connected and the screws in the back of the cluster are tight. definatly check fuses. there is one that controls all this stuff and it might be blown. i just saw someone post it up in another thread cause the guy doesnt have turn signals but has parking lights. search for that and you might get your answer
b20acura
01-14-2012 01:02 AM
99CivicSiBrian
02-24-2006 03:32 PM
