92-95 Manual Pedal Assembly Question
I was looking to do an auto to manual conversion on my 94' civic coupe. I was wondering 2 things. Are all d-series manual trannys the same as far as mounts go and if so was there any car in the 92-95 range that used a cable clutch as opposed to the hydro one. The reason I'm wondering is because I have a spare 4th gen civic d series tranny, but its cable. So If I have to do a conversion or swap out cases it wouldnt be a problem. Just wondering. Thanks in advance.
Seagull Management
Re: 92-95 Manual Pedal Assembly Question
You need to use a custom upper transmission mount and possibly lower transmission bracket when using an EF cable tranny. Just get any '92 - '00 D-series tranny, you can find DX trannys for almost nothing.
So if I am to use the 92-00 dx tranny. All the mounts from the auto will still work with the manual trans? Thanks.
p.s. I'm going to be swapping in some si gears anyways so the trans really doesn't matter all that much I'm just basically buying it for the case and differential.
I believe the automatic cars have a different mount on the tranny side, but there is a conversion mount that bolts to the tranny you can buy instead of welding in a new chassis mount.
Seagull Management
Correct.
I ahve had about 4 transmissions before. All of the 4th gen civic lx cases are small bearing, but both the crx si tranny case that i used and the tranny that came with my motor in my 4th gen (JDM D15B) use a big bearing. So I still have a spare si differential with a big bearing as well as 2 spare lx (small bearing) differentials. All open differentials sadly. Mine is the si trans and the JDM Lsd in it. In my 4th gen it is. So im hoping to swap in an si diff, if it fits, and put the si gears and sychros in as well. Thanks for all your help guys.
moosepoop21
07-26-2006 07:05 PM
Hatchback_bandit
06-24-2005 02:33 AM
