How to fix running rich?? Em1
Old 03-18-2009, 08:36 PM
taimysho0's Avatar
Default How to fix running rich?? Em1
hello i think my car is running rich, when i turn it on for a cold start with garage open, it really smells like gasoline int he garage. also, it backfires alot more than it used to. example is if i put it in 3rd gear, and gas it to about 6k rpm and then let it decelerate back to 800rpm, it will backfire at least 4 times on the way down. how do i fix this? also, i just got new spark plugs, some autolites. i know theyre cheap brands but they were free (discount), would it REALLY help that much if i got some ngk's? thanks!!
Old 03-18-2009, 08:42 PM
racebum's Avatar
Default Re: How to fix running rich?? Em1
check engine lights?
larger injectors, too much fuel pressure, out of time and a host of other things can contribute to this. people need more details to even try and help you. telling us you run rich is similar to saying "my car won't start"
Old 03-18-2009, 08:45 PM
taimysho0's Avatar
well iono, my car is bone stock, i dont have any engine mods besides a kan n filter
taimysho0's Avatar
no check engine lights
Old 03-18-2009, 09:13 PM
taimysho0's Avatar
hello? any1?
Old 03-18-2009, 09:19 PM
angel_i's Avatar
Are there any other modifications other than the filter?
Old 03-18-2009, 09:20 PM
JDMgunmetalCRX's Avatar
run some seafoam thru that bit CH!
it might solve it...if not it'll definately cure your idling troubles!
Old 03-18-2009, 09:21 PM
93egSLEEPER's Avatar
get a set of ngk plugs. the ones you have might not be gapped right causing combustion problems
Old 03-19-2009, 04:18 PM
taimysho0's Avatar
bought some ngk spark plugs today, and it drives a bit better and no more backfiring, however on the way home i heard 1 backfire but it might be normal. i have a custom axleback pipe for my exhaust. also when ic hanged the plugs, i noticed my spark plug wires were kinda bronze/yellow color for the part that goes intot he spark plug hole. is this normal? im planning to buy new ones anyway, does it matter if i get ngk brand or justa generic brand? thanks!!
Old 03-19-2009, 04:27 PM
taimysho0's Avatar
hello?
Old 03-19-2009, 05:13 PM
kenny707's Avatar
i dont think the brand of the spark wire plugs matter because ive been running some autozone ones for a while and no problems yet.
also try to check the rotor and cap while your at it.
Old 03-19-2009, 09:31 PM
taimysho0's Avatar
can some one tell me if the color of the spark plug wires being yellowish bronze is a normal sign? original color is black but like half of it is covered in the yellow bronze color. thanks
Old 01-15-2010, 10:43 PM
ScottF's Avatar
http://www.theultralightplace.com/sparkplugs.htm
408h22a1
02-28-2013 11:36 PM
PhilMac23
Honda Civic (2001 - 2005)
11-05-2012 11:30 AM
neodre
09-15-2006 04:29 PM
Hcivic88
06-30-2005 03:53 PM
Quick Reply: How to fix running rich?? Em1
